Undersaddle pickup http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=46554 |
Author: | aqualibguitars [ Mon Oct 26, 2015 1:54 pm ] |
Post subject: | Undersaddle pickup |
Hello friends. i hope all of u are doing well. i have purchased an undersaddle pickup fishman 301 presys. i want to ask that the undersaddle pickup is little longer than the bridge slot. should i use it as it is and bend the pickup or should i cut from the end of exact size to fit in saddle? waiting for ur advice Attachment: s-l1600 (2).jpg Attachment: s-l400.jpg
Author: | Chris Pile [ Mon Oct 26, 2015 2:34 pm ] |
Post subject: | Re: Undersaddle pickup |
Don't do ANYTHING to the pickup, or it will no longer function. Rout the slot out to fit. |
Author: | Pat Hawley [ Mon Oct 26, 2015 3:01 pm ] |
You don't need to do anything. It's OK if the pickup is a little longer than the slot. Put a little ramp, i.e. file off the edge, of the hole that the pickup goes through so that it's not bending over a sharp edge. Pat |
Author: | kencierp [ Mon Oct 26, 2015 3:08 pm ] |
"Sonicore" pick ups can be bent -- do not trim http://www.fishman.com/files/sonicore_g ... nglish.pdf |
Author: | meddlingfool [ Mon Oct 26, 2015 3:19 pm ] |
Exactly. Drill the hole through the saddle slot at as steep an angle as you can without hitting the x brace inside. Chamfer it just slightly. On the other end of the slot, drill another hole at an angle, but not all the way through, to tuck the crimped end into. |
Author: | doncaparker [ Tue Oct 27, 2015 7:06 am ] |
The Fishman website has installation instructions for both the transducer and the preamp. The transducer instructions show a single hole under one end of the saddle, so I think putting the end of the transducer flush against the non-hole end of the slot, then bending the element 90 degrees at the hole, letting the extra go down the hole with the cable, is what Fishman recommends. Having said all that, I hope you are putting this into a guitar that is neither objectively valuable nor precious to you. That rectangular hole you have to cut in the upper bout pretty much marries this guitar to this type of pickup. I would go with something less destructive, but that's my curmudgeonly side showing itself. |
Author: | aqualibguitars [ Tue Oct 27, 2015 7:40 am ] |
Thanks friends |
